Detroit Diesel pulley specs/replacement
I have a Detroit Diesel 6-71N engine with a 2-groove 5" "auxilliary" pulley. The DD part number is 5133615. The bore on this measures to be 0.985 inches and possibly tapered. A 1" shaft will not penetrate the bore (which is clean, etc.) The keyway is 3/16".
Does anyone know if this is in fact a nominal 25MM bore rather than 1"?
I need to replace this with a 7" pulley. Does anyone know the DD part number for that?
I tried a 2AK74x1, but its pretty loose on the shaft and has a 1/4" keyway.
Any other thoughts and/or suggestions?
Bob
Bob
RE: Detroit Diesel pulley specs/replacement
Russell Giuliano
