AutoCAD Drawings That Triple In Size
We have been having a lot of problems with drawings. I had a drawings that was 5MB in size this morning when I started on it and not it is 30MB. The only thing I did was change the titleblock and switchged places with four other things. I know how to fix the problem to get it back to 5MB but I was just wondering if anyone else has been having this problem.
We are running R14 on an NT4 network. This just started happening recently. It's really weird. I don't know if it's a network issue (we have a lot of those) or something goofing in AutoCAD (we also seem to have that problem a lot). Sometimes we can't run certain command on CAD until the IT department frees up some network space.
Just interested in some ideas if anyone has them.
Thanks!
Thanks!
RE: AutoCAD Drawings That Triple In Size
May not work. Just a suggestion.
Please, consider referencing the border, title block on to the file and insert the title fields on to the drawing via an attibuted wblock which contains the fill in information you require.
The title block data is still available for data extract.
Referencing the borders adds zero memory to the drawing file and if the border has to be fixed for some reason the border file is changed at one location and the whole project gets updated instantly. Also, should you want to use the same project for another client, copy the project to another folder along with the referenced border change the border to accommadate the new client and the preliminary working copy is ready to go for markup.
ODE.
I just want to know why - or if anyone is having the same type of problem. I know how to fix them but it's a pain to. I was hoping someone out there could tell me it's something wrong with my AutoCAD or it's a network problem or something.
