SA213-304 vs A511-304
Sorry, made a mistake. Let me start again.
SA213-304 and A511-304 have the same UNS # - S30400.
Could they replace each other for the media acrylic?
Thank you in advance.
RE: SA213-304 vs A511-304
Depends upon the application & whether codes (e.g., Boiler & Pressure Vessels) apply.
UNS S30400 is just a composition of a very common stainless steel.
ASME SA213, ASTM A213 & A511 are product specifications [SA indicates the ASME adaptation of an ASTM A specification].
A213 Standard Specification for Seamless Ferritic and Austenitic Alloy-Steel Boiler, Superheater, and Heat-Exchanger Tubes contains performance test requirements, including flattening & flaring, not in A511.
http://www.astm.org/cgi-bin/SoftCart.exe/DATABASE.CART/REDLINE_PAGES/A213A213M.htm?L+mystore+pspa0654
A511-04 Standard Specification for Seamless Stainless Steel Mechanical Tubing includes some dimensional tolerance requirements (& even square tubing] not found in A213.
http://www.astm.org/cgi-bin/SoftCart.exe/DATABASE.CART/REDLINE_PAGES/A511.htm?L+mystore+pspa0654
SA versions are available through www.asme.org & your countries governing board for pressure vessels, etc.
ASTM A511 Standard Specification is not endorsed by the ASME B&PV Code.
Whatever code you are working to, if any, I would probably not use mechanical tubing for pressure-retaining.
Mike
Thanks three of your input.
So legitimately we can not use A511-504 for pressure vessels or tubes designed to ASME VIII, right?
Thanks again.
CORRECT.
Metengr,
Thank you very much!
