Dimensioning drafted plastic parts
Hi all,
Is there a recommended way to call out dimensions on plastic parts that have a draft on them?
Like for instance distance between two surface that are drafted. The way I have done is to call it out from the point where my draft starts (neutral plane)but since the angle is so small, it is hard to make out where the extension line is from.
Appreciate your comments....
Thanks in advance
Thanks in advance
RE: Dimensioning drafted plastic parts
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
