Correct pump for a cooling tower
My question is this. What is the best pump to use to circulate water on a cooling tower..Would it be a positive displacment internal gear pump????
RE: Correct pump for a cooling tower
Reidh
In all the refineries I've run the pumps are CENTRIFUGAL. Ther are cheaper and will give you the volume of water required.
As Reidh says, what are your required volumes and what is the height of the tower? With this information it is a simple task to source the right pump.
