no manual entry allowed in HEC-HMS
I'm running into a problem when I try to insert a time series data for a precipitation gage using "manual entry". HMS (v3.0.1 or 3.1.0) does not allow me to enter any data manually, even though the option is chosen. Also, it always shows the fields for latitude and longitude, never shows the single field for gage elevation. Am I doing something wrong? Running on XP SP2.
egcp
RE: no manual entry allowed in HEC-HMS
On 3.1 you should get a plus sign for your gage (next to it)(assuming you added a time series component which it sounds like you did).  Open it and then you get the input tables.  You should get 3 additional tabs one for some controls, the next is the table to add your data, and the last is a graph of the data you have entered.
