Non destructive method to detect calcification in pipes?
I'm working on a peoject where a building ran for over 30 years without a water softening system. Pipe sample has been taken and there is considerable calcification of pipes. The system now has a softener, but there is (I am assuming) a lot of pipe that has severely compromised flow. I'm looking for the best method to make recommendations on how much of the pipe should be replaced. I have read articles about ultrasonic detection, but have yet to find any field test devices.
Any suggestions?
Any suggestions?
RE: Non destructive method to detect calcification in pipes?
I think that pipe samples at various locations will be enough to get a good idea of what can be salvaged. A better solution would be some non-destructive method that would enable me to check everything at much lower cost and consequence.
Also you might try a pipe camera. You can rent one of these too.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
Stephen Argles
Land & Marine
www.landandmarine.com
I'm a great fan of looking for real time solutions, can I suggest you look at the following link of pipe scanning
h
It will help in determining how much of a problem there is
It looks like you have something else going on by the looks of the deposit on the brass valve.
If you see anything on a couple of shots I would take the inspection money and apply it to the cost of chemical cleaning.
Here is a very good chemical cleaner, Rydlyme. I would give these people a call.
http://www.rydlyme.com/home.html
Without the diameter of the pipe bore, you don't have a volumetric flow rate.
Or, am I missing something?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I don't know if radiography will reveal anything on the ID. I would check into it as unclesyd suggested. Call up a radiography outfit in your area and discuss it with them. I think some types of ultrasonic inspection will detect buildup on pipe ID too - your radiographer should know that also. So you need to look in your area for an x-ray/non-destructive inspection company.
Buildup on the valve is probably leakage from the bonnet or stem packing.
However- given the level of scale in the (random?) sample you have above- I'd look at cleaning the piping system. Beign a hospital you will need to be very careful to do it a section at a time and isolate/clean/flush the subsections.
Where was the "leak" on those tanks awhile back?
BigInch
