CAE: how to create a 3D spline or helix ???
I am using abaqus cae to create a helix (inside) touching a shell cylinder. I need to independently create the sections for the helix. to make it clear; cae revolves the rectangular section in an angle (specifying the pitch) and the cross section (perpendicular to any line on helix) dimensions of the revolved section are not the ones I provided.
So i am now trying to specify the path using spline and then sweep the section thru it. But i cannot find a way to create a spline in 3D space. how can i do this?
anyother way to create a helix with a specified dimension? I mean iam concerned about any given section perpendicular to the helix path to be precise. Thank you in advance..
RE: CAE: how to create a 3D spline or helix ???
(watch the indents, they may get mangled in this forum)
from abaqus import *
from abaqusConstants import *
Mdb()
rad = 5.0
zFactor = 0.25
p = mdb.models['Model-1'].Part(name='Part-1', dimensionality=THREE_D,
type=DEFORMABLE_BODY)
xyz=[]
for i in range(100):
x = rad*cos(i/5.0)
y = rad*sin(i/5.0)
z = i*zFactor
xyz.append( (x,y,z) )
for j in range( len(xyz) ):
dtm = p.DatumPointByCoordinate(coords=xyz[j])
d = p.datums
p.WireSpline(points=d.values(), mergeWire=OFF, meshable=ON,
smoothClosedSpline=ON)
session.viewports['Viewport: 1'].setValues(displayedObject=p)
any help would be highly appreciated !
thanks again for the help
width = 20.0
height = 5.0
origin = (15.0, 0.0)
pitch = 50.0
numTurns = 2.0
s = mdb.models['Model-1'].ConstrainedSketch(name='rect', sheetSize=200.0)
g = s.geometry
s.setPrimaryObject(option=STANDALONE)
cl = s.ConstructionLine(point1=(0.0, -100.0), point2=(0.0, 100.0))
s.FixedConstraint(entity=g[2])
s.FixedConstraint(entity=g[cl.id])
s.rectangle(point1=(origin[0], origin[1]), point2=(origin[0]+width, origin[1]+height))
p = mdb.models['Model-1'].parts['Part-1']
p.BaseSolidRevolve(sketch=s, angle=numTurns*360.0, flipRevolveDirection=OFF,
pitch=pitch, flipPitchDirection=OFF, moveSketchNormalToPath=OFF)
#In above command try changing the following member: moveSketchNormalToPath=ON
s.unsetPrimaryObject()
