How To Replace An Inserted Part (Base Part) In A Part?
In an assembly the Replace Components function exists. Is there an equivalent function for replacing a base part (Insert > Part) in a part?
![[cheers] cheers](https://www.tipmaster.com/images/cheers.gif)
RE: How To Replace An Inserted Part (Base Part) In A Part?
Everythign we've seen here with the Insert>Part feature in a Part says that once a part is in that is it, it's in. I don't think there is an equivalent feature at the Part level of the REplace part assembly command.
Similar to switching references in a drawing?
1) Open the finished part.
2) Edit the base part.
3) FILE - SAVE AS - New base part number.
4) CTRL-TAB back to the finished part so it updates and SAVE.
Now if you have to, you can substitute base parts/ part numbers. (or modify the original base part to suit..)
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
Pete
Thank you.
meintsi ... Thank you but the parts I am inserting as Base Parts already exist and have been used elsewhere.
