Need help wiring a 380v motor with switch and light bulb
I need help with a new machine design.
A customer is requesting a 380V 3-phase 50HZ 1HP motor on a machine. The motor will run a single speed for a grinding operation. They will be supplying 380V 3-phase.
Our machine also has a incandescent work light that typically matches/uses the input voltage supplied. What voltage and/or light bulb should I use for the work light? Do I need to step down voltage for the light, and if so, how would I go about doing this? (what is the common lighting voltage for 380V machines?)
Also the customer has requested a lighted on/off switch for the motor. I am searching for a possible switch but having no luck.
There is a possiblity that I can use a panel mounted indicator light that would signify the motor is powered on.
Any help would be much appreciated.
RE: Need help wiring a 380v motor with switch and light bulb
I do not think that your customer will be very pleased to find a 120 V outlet on his machine if he has 230 V hand-tools.
You should ask the customer about this. We can only guess.
Gunnar Englund
www.gke.org
Is there a way to switch this small motor without a contactor? Is there a common switch that would handle the motor draw and safely disconnect all leads from the 380V?
I am assuming that when using a contactor for motor control in this situation, I could use the 120V circuit and switch to trip the contactor. This would also illuminate a motor on indicator light or illuminated switch.
As to the motor control, if this is a simple manual operation such as on a bench grinder, you will still need to provide running overload protection for the motor. You need to supply a simple manual motor starter. The type used in most IEC countries (meaning not North America) is a very simplistic manually operated device with a on-off button or switch like a light switch along with an adjustable overload trip element. Here is an example:
motor protectivce switch
Can someone please clarify one thing for me? Is it OK to tie the neutral to ground in this situation? Or will there be a seperate ground with the 3 phases and neutral?
respectfully
The TN-C system has a combined PE and N conductor and does not need two separate wires for PE and N (that's the reason for the "C" - as in Combined).
TN-C systems are a lot more common than TN-S (you guessed it, "S" stands for Separate). In both cases, there are two separate conductors going from the fuse-box to the machine.
The N is light-blue and the PE has yellow/green stripes. You are not allowed to connect anything current-carrying to the PE - all single-phase returns shall go to N.
Gunnar Englund
www.gke.org
There's a good summary of the European harmonised colour code in this link:
ht
Sometimes I only open my mouth to swap feet...
It will at least serve to bolster my wife's perception of my being "a fountain of useless information".
