code case 2235
code case 2235
what does code case 2235 tell us? can we use A scan ultrasonic in lieu of radiography? or we shall use only C scan?
RE: code case 2235
ASME Code Case 2235-9 allows for the ultrasonic test (UT) method to be used in lieu of RT for material 1/2" or greater in thickness in boilers and pressure vessels. You have to develop a scan plan (ultrasonic beam angle, direction and volume of weld metal, etc.) and have to develop a written procedure for the UT method in accordance with Article 4 of ASME Boiler and Pressure Vessel Code, Section V.
I am not going into greater detail, you need to obtain a copy of this CC and review it. However, if you want to wait until the 2007 Edition of the ASME B&PV Code, the SG on FE and SCI on Power Boilers will be integrating this Code Case in PW-52 with a new Appendix A-280.
RE: code case 2235
ASME Code Case 2235 contains an ultrasonic defect acceptance criterion based on defect height vs length vs through weld location in line with a fracture mechanics analysis. Generally only automated or phased array UT will allow the necessary proven accuracy in defect height measurement to justify its use. AUT has proved to be highly-effective for pipeline girth weld testing where the high set-up costs are offset by the speed and efficiency of the test.
In January this year ASME issued Code Case 181 for B31.3 Process Piping which appears to be identical.
Nigel Armstrong
Karachaganak Petroleum
Kazakhstan
RE: code case 2235
see this link... http://www.sonotronndt.com/pdf%5CASME.pdf to read cc2235
