INFO G(II) TOUGHENING EFFECT
WHEN I DO END NOTCHED FLEXURAL TEST ON COMPOSITES LAMINATES I MUST DETERMINE THE G(II) [RELEASED ENERGY]. I USE THIS EQUATION:
G=(9*P^2*a^2)/(16*E*H^3*B^2)
WITH "a" CRACK DIMENSION.
WITH THE TOUGHENED EPOXY RESIN I MUST FIND THE G(II) GREATER THAN UNFILLED RESIN?
a SECOND QUESTION IN THE EQUATION THE "E" VALUE THAT I MUST INSERT IS THE "E" VALUE OF THE UNIDIRECTIONAL 0° MODULUS OF THE LAMINATE WITHOUT CRACK, OR IT IS THE MODULUS OF EVERY SINGLE TEST (SO IT CHANGE ON EVERY TEST BECAUSE IT DEPEND BY THE DIMENSION OF THE CRACK)?
THANK YOU IN ADVANCED FOR THE ANSWER.
LUIGI74
LUIGI74
RE: INFO G(II) TOUGHENING EFFECT
There are some other issues you may want to address also.
Please contact me at:
bawatson@raytheon.com and/or bahiy_a_watson@yahoo.com
