Batch Plotting in NX4?
Hi Guys,
Does anyone know of a way of plotting a series of PRT files without having to open each file individually? I was hoping for some form of command line method so it can be performed outside of NX.
I looked at the help menu, but the closest it gives is using NXPLOT to plot CGM, JPEG and TIFF files from the command prompt.
Many thanks,
Andy.
(Using: UG NX4)
Design Engineer
RE: Batch Plotting in NX4?
No, I'm not working for a GM supplier (I work in the Orthopaedic Implant industry).
I don't think there's an easy answer for this.sad
- Andy.
(Using: UG NX4)
Design Engineer
You can create a program to open a ug file and print it out however you would need to know how to use Visual Basic or a similar programming language. The program would need to index down the list of files in the directory and then open them and print them.
Mark Benson
CAD Support Engineer
Many thanks for your reply. I am currently trying to learn VB so we can customise some of the NX functionality.
Would you have any tips/help you can offer on the best approach to this problem?
Any advice would be greatly appreciated as I am still on the rather large VB learning curve. sadeyes
Many thanks,
Andy.
(Using: UG NX4)
Design Engineer
Check out the sample directory located under the UGII_BASE_DIR location (C:\Program Files\UGS\NX 3.0\UGOPEN\SampleNXOpenApplications) there is one example regarding DrawingCycle, that you could modify to print.
-Dave
http://plmwiki.com
http://groups.google.com/group/NX_CAX/
Hi Andy,
I would too be interested if you succeed to create such a program (plotting a series of PRT files without having to open each file individually).
Thanks in advance
Didier
Chedck the GRIP Library. There is an older program named PLOTGEN that may be modifiable to a windows environmnet. It was originally written for VMS.
Ben Loosli
Sr IS Technologist
L-3 Communications
