BSP & NPT Fittings in DN40 & 50 PE or PP
I am seeking a manufacturer of a PE or PP plastic pipe system that has fittings with both NPT and BSP threads to join to two sources of equipment. This is the only issue. I already how the piping will be run it is just finding one system with both thread forms that is the dilemma.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: BSP & NPT Fittings in DN40 & 50 PE or PP
I'd check George Fischer or Spears Manufacturing.  I'm not sure about the availability of the fittings in PE or PP.
I know GF makes a welded PP system with threaded adapters (in both NPT and BSP I think)
Spears is primarily PVC/CPVC, but they do show some PP in their literature.
