After to change the drawing sheet background, how to save?
How can the background be saved as a template so that you can use it over and over?
RE: After to change the drawing sheet background, how to save?
Then when you create new drawings, go to file, page setup, insert background view and browse for the file you just saved.
--Jay
My part is in inches. I started a drawing and specified ANSI-B (11x17).
My dimensions are coming up in mm. How do I change a sheet to be in inches?
Search the forum for drafting standards - this topic is beat to death. Also check FAQ, another good spot for info on the matter.
Derek
There are more standards available. Try them all to see what they look like.
Another question: I changed the XML file to .001 to get three decimals. However, it still shows a value such as 0.130 as 0.13. Why is it not showing the 3rd 0? It is significant to me as I want the machinist to know that I always care about thousandths.
I would like to globally change this and not one at a time.
The setting for trailing zeros is under
Tools-Options-General-Parameters and Measure-Units
