print to file ?
print to file ?
when i try to plot with the SDI print master, i can't pick "print to file" cos it's greyed out, but i can't sus it out from the help, it only seems to show me how to add printers etc, i don't need to set it up to a printer, cos i'll only be printing pdf's from the .cgm files
Can anyone help ?
Can anyone help ?
RE: print to file ?
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: print to file ?
RE: print to file ?
add the requested printer.
good luck
Jelmer Rouwé
RE: print to file ?
You will need to install the pdf995 software before you try to add it as a printer/plotter.
RE: print to file ?
One more question, where do i set the directory to which the saved file will be written ?
RE: print to file ?
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: print to file ?
But we have one called " cute PDF "
i've installed it but i can only get it to work by using "file print " but not with " file plot "
Any ideas ??
RE: print to file ?
Since it appears that you're still a bit shaky about how to get the proper setup for Print to File to work, you should probably call GTAC for some phone support, if you're paying for it monthly. There are also some PDF guides on the GTAC support site that pretty much covers how to deal with the Print Admin.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
RE: print to file ?
