Column and Shear wall
I want to know if we model the wall between the columns, attached to them, should we delete the columns or not (I mean in reality are the columns exist in the system?) Some believe they can be exist and design them as a column but I cant accept this idea because I think the Connection between wall and column make them as a unique wall element. (in Seismic Design Handbook by F. Naeim no column has been modeled.)I am mixed up and need help. thanks alot.
RE: Column and Shear wall
benjaman
The only way to avoid plastic hinging under certain loads is 1. Not to have those loads or 2. Design the system of elements so robust that there is no money left over for the fancy architechual adornments!
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
you should design the column and the wall separately. your wall will be design as shear wall making your column a supported one.
fratrowie
thanx for the correction......................
What will happen if we delete the Column? and what will we get if model the column and design it ? I think in this situation column act as a part of wall.
but in detailing i do not know what would be the connection between Horizontal Rft of the wall and the column Ties
Alirezai, we try to keep from posting copies of threads in other areas so we don't waste the members time answering questions that have been answered elsewhere. It also keeps all the information in the responses in one place.
