50Hz Instrument Transformers on 60Hz System
Hello Guys,
I'm new here and I don't know yet if there are threads related to my question.
We ordered this Medium Voltage Switchgear (15kV) from Italy and we make sure that during the ordering process we specified a 60Hz System since we are here in the Philippines; Yesterday we found out that the instrument transformer (for metering and relaying) installed are all rated 50Hz. We already informed the manufacturer about that matter and at the same time we need also your advices.
Is it ok to use it?
Thanks a lot in advance.
ramski
Is it ok to use it?
ramski
RE: 50Hz Instrument Transformers on 60Hz System
Hopefully ScottF will give us a more detailed answer when he sees this thread.
Sometimes I only open my mouth to swap feet...
respectfully
If you're using for revenue metering though, you may need to get them re-certified.
Regarding the comments above about heat, I can't see that being an issue. It would only be a possible concern for VTs and, unless you're loading the VTs up to the thermal burden rating (i.e. a powering application), they would not be running anywhere near their rated temp rise class. Should have no impact on their life or performance.
I just one to ask one more thing, Does it affect the Ratio (output) of the Instrument Transformers?
I would not expect it to be enough to be an issue.
Best regards,
Mark Empson
http://www.lmphotonics.com
No...there is no appreciable effect on the ratio, i.e. ratio error.
