Increasing radius pattern.
Lets say you were making a block to hold gauge pins.  How would you drive 250 extrude cuts with an increasing diameter. They do not have to be equally spaced.
I have been trying in a sketch to drive it every which way but I just cant get it to work.
Josh
p.s. I can make it happen in NX4, but not in solidworks.
RE: Increasing radius pattern.
Can you use a Spiral curve for a radial pattern?  Check out Curve-Driven Patterns in Help.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
But I want each extrusion to be .001 bigger than the last.
Josh
Oh, now I know what you mean--I'll have to think about that.  Maybe with a Design Table?
Jeff Mowry
Sounds like a job for a drawing macro with user inputs for start diameter, size increment, pitch, direction and number of iterations.
cheers
I'd suggest a macro.  I'm not really familiar with the SolidWorks API, it'd be easier for me in AutoCAD.  I'd record a macro of sketching a circle, examine the code, then set up some sort of recursion to get your pattern.
How do you do it in UG?
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP2.2 on WinXP SP2
I would create an instance, and then drive that instance via expression.
