The Magic Disappearing Views!
Has anybody seen the issue where SW will magically and randomly decide that it wants to draw the annotations and such on a 2-D view, but not the model that is in the view? I'm running 07 with SP 2.2 installed, but I saw this issue in 06 as well.
RE: The Magic Disappearing Views!
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Can you explain better or show an image?
Heckler: I'm currently running a Xeon 2.8 with 1 GB of RAM and an NVidia Quadro FX500.
Does this happen with other files too?
A work a round is to convert the view to draft quality the when you print check the box convert draft quality to high quality
Another thing to try is tern the image quality down a notch or 2
We've also used another work-around, with good results, but it doesn't always work: Click in the view, then switch that view to wireframe and then back to what it was.
I had that problem and I think I have fixed it.
Probably, you are doing two things.
- You are allowing SolidWorks to switch views to draft mode.
- In the print window you have clicked "Convert draft quality drawing views to high quality".
Turn off the "Convert draft quality.." button.Click on each of your drawing views and look in the browser under "Display Style". This probably will indicate draft mode. Turn this off. On old, converted drawings, the option disappears, which is fine by me.
JHG
