Autocad
Autocad
Hi all, Can autocad dwg be imported into Catia and extruded to a 3d?
RE: Autocad
javascript:openindex(450,450,'h
or search for
import .dwg
Derek
RE: Autocad
RE: Autocad
Anyway, AutoCAD drawings open in Catia - but they are always behind by what seems like at least 2 versions. As of R17, I am able to open AutoCAD 2006 files, but not AutoCAD 2007. It took an act of God just to get up to that version. So depending on what release of Catia you are using, you may or may not be able to open a certain AutoCAD file.
Catia Design|Catia Design News|Catia V5 blog
RE: Autocad
I coudn't get the thread link to work when i tried to insert it, so i've made a copy of the text in that thread and placed below in blue.
Btw the first method worked best for me.
Eng-Tips Forums http://www.eng-tips.com/
AREA: Engineering Computer Programs/General Engineering Programs
FORUM: CATIA products Forum
SUBJECT: import .dwg into catpart or catprod
HANDLE: alkemixt
POSTED ON: Mar 1
QUESTION:
I have a .dwg file created by Autocad, and I want to import this into my Catpart, either as a sketch or as a 3d lines.
is this possible?
thanks
DBezaire
POSTED ON: Mar 1
REPLY:
You have to bring it into a drawing first, then copy paste it to a CATPart.
or
Bring it into the drawing file, then save it out as a .ig2, this is a 2d iges file.
In windows change the extension to .igs
This will come in as a CATPart file.
Derek
alkemixt
POSTED ON: Mar 1
REPLY:
you da man!!
thanks-------------------------------------------------------------------
alkemixt
POSTED ON: Mar 1
REPLY:
just out of curiosity, is there any other way to import these 2D model into 3D? changing the file name to fool catia seems kinda silly..:) but it works...-------------------------------------------------------------------
DBezaire
POSTED ON: Mar 1
REPLY:
I am only aware of the 2 methods, filename change and copy paste from drafting to modelling.
Derek
RE: Autocad
RE: Autocad
RE: Autocad
RE: Autocad
From what your saying I understand, importing a DWG (nothing complex)into Catia can be extruded?
RE: Autocad
Draving -> save as IG2 -> save as DXF -> paste to part
Maybe same applies to Autocad.
Rgds,
Damir
RE: Autocad
Derek
RE: Autocad
RE: Autocad
RE: Autocad
RE: Autocad
See http://2htts.com/CATBlog/index.php?itemid=34
For those 5000 drawings it will be better to run a macro over night.
See also CATBlog for a batch conversion...and with some modifications you can run and save at least first sketch in new CATParts.
Fernando
RE: Autocad
RE: Autocad
RE: Autocad
Forgot to mention - you really only need to set the Import setting, but since I don't know where you are getting the data, you're covered both ways.
Import will handle your external data, and Export will save you the hassle of having to set the options of your imported text and dimensions when working with your own data. So you can use one or the other, or both.
RE: Autocad
RE: Autocad
Luke
RE: Autocad
Sure. "Save As" .dwg. It's one of the standard translators.
