NX4 - Datum CSYS mating issue
Hi all.
We like to use Datum CSYS to mate components in our 'variable models' assemblies.
In NX4, everything goes well (add component > mate > datum CSYS selection) until
we want to delete a mating condition of a component and mate it again in a new position : then the Datum CSYS of the component is not available anymore for selection !
Did I miss something here ?
Thanks for the help.
RE: NX4 - Datum CSYS mating issue
You may have to do one of two things.  Either make sure that the datum csys has been added the Reference Set that you are using for the component in your assembly, or else replace the current reference set in the assembly with the 'entire part' one.
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
Thanks, John, but I'm already using the 'entire part' ref. set. ... :-/
