building a table of inspection point x,y,z locations on drawing
I have a plastic manifold with inspection points on certain vertices.  I want to build a table on the drawing referencing point name, and corresponding x,y,z coordinates.  How do I do this? I'm working in PRO-E Wildfire 2.0.
CADCATS
RE: building a table of inspection point x,y,z locations on drawing
I forgot to say that I want the table to be intelligent.
Insert a HOLE TABLE. In ProE 2001 this option is under the Advanced feature.
-Hora
I think a hole chart needs to be coplanar with the points. My points are all of the place in 3 dimensions.
Hora,
Thanks so much. Got it working now. For some reason I have to select the CS on the drawing as opposed to the model tree.
Cadcats
