CROP LINES SHOWING...
I am trying to get rid of the lines around the crop view. When I try to crop parts in my assembly it leaves behind the lines I used for the crop I need to get rid of all of these lines. Does anyone know how to do this?
RE: CROP LINES SHOWING...
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Unless you get an approved card and driver combination you will often get graphic anomalies.
Depending on your version and SP this has been discussed on here before. Check thread559-130988. The last few versions did that for me unless I put the spline in a certain way. SW07 doesn't seem to have this problem.
mncad
