Corrosion resistance of 304SS to dilute 0.04% sulfuric acid
I have read the stainless and sulfuric acid posts and looked at the references out of them.
The charts and articles I have found seem vague at these low concentrations. In your opinions is 304L SS piping acceptable in a 0.04wt% sulfuric acid stream at 120 deg F? Are there any specific references I should use for data at this concentration.
Thank you.
Thank you.
RE: Corrosion resistance of 304SS to dilute 0.04% sulfuric acid
http:
Flow rate matters (note, quote is for concentrated sulfuric at ambient T):
"The materials of construction for piping are dependent on fluid flow velocities and quality concerns. In general, seamless carbon steel piping is used for flow velocities between 1-3 feet per second (fps). 316 SS is acceptable for flow velocities of 0-8 fps. Alloy 20 works for flow velocities of 0-20 fps, and TeflonĀ®-lined pipe works for all ranges of fluid velocity. If iron contamination is a concern for the process, stay away from carbon steel. These recommendations assume ambient temperatures. All metal piping should be welded per "ANSI B31.3 - Normal Service" specifications. Screwed fittings are discouraged. PVC and CPVC piping is recommended for vent/vapor lines only. They are not recommended for liquid service."
http://www
For dilute solution at 120 oF, why not use CPVC?
It should be noted that the presence of any chlorides will tip things in favor of 316.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
