Problem with tol_text_height_factor in .dtl
When I adjust the tol_text_height_factor in the .dtl nothing happens. It is my understanding that when I change this ration, the size of my tolerances in the plus-minus format should change accordingly relative to the dimension text size. Oddly enough the tol_text_width_factor seems to work find for me.
Has anyone experinced this before. Is it a build related issue? Are there any settings that might overide this?
I am using Wildfire 2 build M130.
RE: Problem with tol_text_height_factor in .dtl
