Parts Location
Parts Location
I have a design folder containing assy, parts and drawings which has been supplied by a third party. I now need to move these files from this temporay folder to the correct directories on our server. My fear is that in transfering the files, assy links will be lost. Any suggestions?
Thanks in advance
Thanks in advance
RE: Parts Location
Or, move the parts, then go into Tools/Options/File Locations and add the new folder location. Move it to the top of your list, and SW will look there and find the parts.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Parts Location
Are the files all in the same directory? If they are, you should not have a problem moving them, as long as they are all moved to the same location. However, if the files are in different directories, MadMango's advice is on point.
RE: Parts Location
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 02-10-07)
RE: Parts Location
RE: Parts Location
I like CBL's recommendation on "Pack-and-Go".
RE: Parts Location
Do a save-as
In the save-as box select the references... button at the bottom
Select a part
At the top select browse
Browse to the location that you want that new file to be located.
Hope this helps
B. Long
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
RE: Parts Location
I went down the route of tools/options/file locations, added some more folders to the list and it worked out fine.
