Crosshatch selection in models and drawings
Is there way to change a crosshatch in a drawing file, in my case the scale, without clearing the check in the ‘material crosshatch’ box? We want the model material to drive the drawing for crosshatch selection. The problem we have is the default at the model level is at a scale of 1 and appears it can’t be changed...at least with my 4 eyes anyway. If the part is small, it’s hard to determine the crosshatch. Our users will edit the scale of the crosshatch in the view but that removes the driven parameter set at the model level. Keep in mind this isn’t a stop, drop, and roll problem. However, I am curious to hear from users how they handle the material/crosshatch selection in part and model files. Tips and tricks from seasoned SolidWorks users are always useful.
Edson Gebo
Co-Chair of the CMNC-SWUG
http://webpages.charter.net/cmnc-swug/welcome.htm
Mechanical Designer/Drafter
SW2007 SP2.0
Cadra 2006 (yup 2D still exists)
Sometimes Success Begins at Failure
RE: Crosshatch selection in models and drawings
I don't have Sw07, but in SW05, go to Tools/Options/Drawings and select the sub item Area Hatch/Fill.  You should be able to change the scale there.
If you are using part templates, you may want to save several different part templates to represent small, medium and large parts with the scale adjusted so the cross hatching looks correct for the drawings.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
