Why is it?
Why is it?
Hey Guys...
Lets say I have a part that was imported .stp, igs what ever. The part imports with errors. If I go in and try to extrude off the offending flange(s)I receive an error that it does not intersect with the model, even though it is shown in a preview that it is cutting thru. I'm doing this by sketching on one of the planes.
Any ideas?
Ken
Any ideas?
Ken
RE: Why is it?
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
President: www.nvtswug.com
SW 2007 SP 2.0
RE: Why is it?
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
RE: Why is it?
Seal your surfaces by importing with the Diagnostics on import, or do it manually with Surface tools. You can then Knit the surfaces, selecting the Make Solid option to create a solid (also other ways to make a solid, but this is simple if patching surfaces manually).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
RE: Why is it?
I'll try playing with the surface tools and see what happens.
Ken
RE: Why is it?
Jeff Mowry
RE: Why is it?
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
RE: Why is it?
Thanks everyone.
Ken
