Simulating Deformation of Plastic
I have a plastic cover that is not designed to be stacked, but it has been required to determine how many of these covers can be stacked. I'm looking for suggestions on how I can possibly deform these shelled part models to simulate the expansion and compression of these parts when stacked.
I cannot redesign the parts, as the $50k mold is are already in process. This is a bean-counter exercise to determine how many covers can fit on a standard pallet.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Simulating Deformation of Plastic
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 02-10-07)
However, if you learn the difference between a Force and a Pressure, you can probably simulate the plastic flexure as needed. It's a hack, and it will only give you as good an output as you give it input.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
I love well defined problems.
