Code Required Footing Ties
Both the 2003 IBC (sect. 1805.4.2) and the ASCE 7-02 (sect.7.9.5.2) require "individual footing" ties in related to code sections on seismic loads for certain Seismic design Catagories.
Can anyone more specifically define "individual" footings?
In a rectangular building with perimeter column footings cast intregrally with the concrete frost walls, would those footings be subject to requiring cross ties perpendicular to the building? Or are the codes referring to isolated spread footings in the middle of the building space?
Also, since the footing excavations within the foundation area are backfilled with compacted structural fill, isn't that considered to afford a high degree of restraint for the foundation?
RE: Code Required Footing Ties
In a rectangular building with perimeter column footings cast intregrally with the concrete frost walls but occuring some distance below the slab, would those footings be subject to requiring cross ties perpendicular to the building?
