Custom Hole Wizard Depths
I'm working on custom hole standards, derived from the ANSI metric database. I would like to change the default end conditions (both tap drill depth and thread depth), but cannot find where these are controlled. I'm working in SW2007, SP2.2
Mike
Mike
RE: Custom Hole Wizard Depths
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 02-10-07)
Mike
They cannot be controlled (I have not found a way either). My suggestion is to set up favorites with the depths you want.
SA
