How to Fix QTY on the BOM
Quantity on my BOM includes the configuration name, such as
6102-2 QTY.  How do I remove the numbers from the QTY column.
RE: How to Fix QTY on the BOM
Double click on the column heading.  Delete the period after "QTY".  Then rebuild.  The config name should go away.  Save this BOM as your new BOM template.
Pete
That works, Thanks Pete.
sg20
