Breast Implant Modeling using FEA in ABAQUS --- How to ??? Your Ideas
I come from a computer science background and hence I am new to both
finite element analysis and ABAQUS.
GOAL ---- I want to study the deformation/change in the shape of a
breast implant under the action of gravity.
According to the shape, Breast implants are of two types:
1. Round Implants -- These are like a hemispherical membrane/balloon
filled with saline solution.
2. Anatomic Implants --- These resemble the shape of the breast more
closely.
The material used for the membrane enclosing the saline solution can
vary and can be assumed to be of rubber-like material for now.
Initially i am only trying to model the round implants.
BOUNDARY CONDITIONS: The back planar surface of the implant should
be completely fixed (ENCASTRE) from any deformation.
I am wondering of what is the correct way to model this problem and
your ideas and sugegstions would be greatly appreciated ...
WHAT I HAVE DONE:
I already have developed an application in C++/OpenGL in which i have
modelled the shape of the breast implant. It allows me to
interactively create various shapes for the breast implants.
From here i get a Triangular Surface Mesh, and i want to use FEA to
determine the change in the shape of this Triangular Surface Mesh
under the action of gravity (when filled completely with saline
solution).
I can convert this to a solid mesh with tetrahedral elements using an
open source mesh generator if a solid mesh is needed.
Your ideas would be greatly appreciated ....
Thanks in advance ....
Deepak
