Integrating accleration signal
We are testing effect of accumulator in rock drill concept. We have mounted two tri-accelerometers in hydraulic hoses that feed the drill to capture the difference in acceleration/frequency, if any.
To my surprise, results were fairly same.
Now, I would be interested in position difference. Integrating signal directly gives garbage. I have tried spline interpolation with still garbage results. Signal appears to shoot way off the course. I do not have much experience in signal processing.
I have 5sec sample with 5kHz. Does someone have insight into this?
suviuuno![[banghead] banghead](https://www.tipmaster.com/images/banghead.gif)
suviuuno
RE: Integrating accleration signal
Cheers
Greg Locock
I filtered signal and got what might be in the right area. Quite hard to say, I think. I'll keep you posted.
But why not just try manually calculating the displacement at a couple of points, based on your acceleration data, and compare that to your integration results?
I've done double-integration on acceleration data a number of times using Head Acoustics' Artemis software, and have always had good agreement with calculated results for individual frequencies, and have only gotten "nonsense" results for very low frequencies.
- R
Cheers, dolsoi
Cheers
Greg Locock
To avoid leakage problems in the freq domain integration, you have to have a signal that begins and ends at zero. The usual approach is to apply a window (e.g. flat-top for a long data record like yours) but windowing is a non-linear process and would screw up your results big-style. The trick is to ensure that your measurement does not require windowing.
Start the da6a acquisition with the drill at rest. Start up the drill. Run it for your 5 seconds. Turn it off. Give it some time for all the vibrations to die away. Then stop the acquisition.
You can then easily fft and integrate and hp filter in the frequency domain without any phase issues and transform back to the time domain.
I have done this, even when the dominant frequency of interest was as low as 10 Hz.
M
Dr Michael F Platten
One rule I have is to apply the high-pass filter as mentioned by Sompting guy (to remove dc component) at each stage. Before the first integration, after the first integration, and after the second integration. There should be no dc in acceleration, velocity or displacement of a stationary vibrating component anyway, so you're not losing any info. With reasonably high sample rate in relation to sampled signal and the understanding that the low freq components have been removed, I believe you can expect good result.s
How do you high pass filter in Excel?
What's the simplest low-pass filter? Moving average. The more points you include in the average, the lower the cutoff.
How to turn into a high-pass filter? Just subtract the moving average from the point. The formula for B101 might be +A101 - sum(A2:A200)/199.
Copy to B102 as +A102 - sum(A3:A201)/199
etc
You end up with the output of the filter having 100 less points on the beginning and the end than the input of the filter... not a big problem if you have a lot of data.
That's just a start. Of course digital diltering is a well-studied field. You can define your filter parameters and determine required FIR filter coefficients using Matlab (and then implement the filter in excel).
Of course google is your friend. Here is a spreadsheet already built:
http://w
Also check out dspguide.com or google for "numerical recipes"
I answered it.
Then you tell me that digital filtering is nothing new to you. Jeesh.
Next time you want to make an editorial comment, please have the courtesy not to pose it in the form of a question so people won't waste time answering it.
Thanks for helpful comments. I am getting reasonable results now, however, I have not verified it by displacement transducer yet.
Thanks again.
suviuuno
