normalisation annealing 304 stainless steel
does anyone know the 304 stainless steels normalization annealing temperature and annealing tine for a wire about 12 micron
RE: normalisation annealing 304 stainless steel
There is probably no reason to go hotter than 1800F, 1750F may even be enough. The time will be just enough to get the material to temp.,seconds not minutes.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Again, just like EdStanless asked above, What are you trying to accomplish?
Rao Yallapragada
Electric resistance heating is the easiest way if you lack furnaces. Not real precise on temperature, though. To protect the surface from oxidation, do under argon inside a quartz glass tube. I've also done a similar annealing in a tube furnace under flowing hydrogen that burned off as it exited one, necked-down end.
Rust never sleeps
