Grease Duct Connection to Upblast Fan
Typical kitchen grease duct application, fully welded carbon steel. Is the connection to the roof-mounted fan welded as well, typically speaking of course. Or is it flanged and gasketed?
Also, separate, but related question. In a fume hood application, with welded, stainless steel exhaust ductwork, is the connection to the fume hood (typically a nominal, round size) a welded connection as well? Is this typically how its done? There aren't any chemicals in use in the hood that will "attack" gasketing, but I am just curious how this connection is typically made.
Thanks again.
Thanks again.
RE: Grease Duct Connection to Upblast Fan
