Freeboard Requirement per Add. 4
I'm currently designing an API 650 tank that has been assigned to SUG I. Per Table E-7, the minimum required freeboard is 0.7d if SDS < 0.5g. What happens if SDS >= 0.5g? The table does not specify what to use if SDS >= 0.5g. Should the freeboard be equal to the wave height should this be the case? Also, the statement in E.7.2, “The purchaser shall specify whether freeboard is desired for SUG I tanks” does add confusion to the situation. The title of Table E-7 is “Minimum Required Freeboard.” Could someone shed some light this direction?
Jorge, Jr.
Alonso & Carus Iron Works, Inc.
Euro-American Steel Co., Inc.
Jorge, Jr.
RE: Freeboard Requirement per Add. 4
For SUG I, it still shows "no minimum freeboard is required" for SDS>0.5g.
Jorge, Jr.
Jorge L. Ramos, Jr., MSCE, PE
Alonso & Carus Iron Works, Inc. (www.alonsocarus.com)
Euro-American Steel Co., Inc. (www.euroamericansteel.com)
