SolidWorks - VB x Borland Delphi
Hi All,
I am trying to use Borland Delphi to write a code in our system.
In VB i have the follow code:
Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swTable                 As SldWorks.TableAnnotation
    Dim swDraw                  As SldWorks.DrawingDoc
    Dim swView                  As SldWorks.View
    Dim swBom                   As SldWorks.BomTableAnnotation
    Dim i                       As Long
    Set swApp = GetObject(, "SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    MsgBox "Running...."
    Set swView = swDraw.GetFirstView
    MsgBox "View: " & swView.Name
    While Not swView Is Nothing
        Set swBom = swView.GetBomTable
        If Not swBom Is Nothing Then
          MsgBox swBom.GetColumnCount
        End If
        Set swView = swView.GetNextView
    Wend
In Borland Delphi i create this code:
    swApp: TSldWorks;
    swModel: TModelDoc2;
    swSelMgr: TSelectionMgr;
    swAnnotation: TAnnotation;
    swTable: TTableAnnotation;
    swBomTable: TBomTableAnnotation;
    swDrawing: TDrawingDoc;
    swView: TView;
    varConfiguracoes, varFeature: OleVariant;
    nrModel, nrConfiguracoes: integer;
    flAtivar, flTopLevelOnly: WordBool;
    stNome: WideString;
begin
swApp        := TSldWorks.Create(Self);               // Dim swApp                   As SldWorks.SldWorks
swModel      := TModelDoc2.Create(Self);              // Dim swModel                 As SldWorks.ModelDoc2
swDrawing    := TDrawingDoc.Create(Self);             // Dim swDraw                  As SldWorks.DrawingDoc
swView       := TView.Create(Self);                   // Dim swView                  As SldWorks.View
swTable      := TTableAnnotation.Create(Self);        // Dim swTable                 As SldWorks.TableAnnotation
bRet := False;  // Dim bRet                    As Boolean
try
   swApp.Connect;   // Set swApp = Application.SldWorks
except
   begin
      MessageDlg('SolidWorks 2007 don't installed !!!', mtWarning,[mbOk],0);
      raise;
   end;
end;
swModel.ConnectTo(swApp.IActiveDoc2);  // Set swModel = swApp.ActiveDoc
swDrawing.ConnectTo(swApp.INewDrawing(-1)); // I want get the current view here, and the system create a new view.
MessageDlg('File : ' + swDrawing.GetNamePath,mtWarning,[mbOk],0);
swApp.Disconnect;
The code run efficiently, but i want to take the current view, and not insert a new view.
The purpose of this code, at last, is to get the BOMTable, to transfer the materials to ERP Application. This code is the just the initial of function.
Adriano
