How can I measure the lenght of a spline?
Hi all,
Can I measure the lenght of a spline or a pline?
Thanks in advance
Matrix
Thanks in advance
Matrix
RE: How can I measure the lenght of a spline?
2. Use 'area', it gives you length as well as area.
3. Use 'lengthen', it gives you cuttent length, then 'esc' to cancel.
If programming, use 'area', then the length is stored in the System Variable 'perimeter'.
Carl
Matrix
