concrete design spread sheet
I have an old and unfortunaly corrupted Lotus file on concrete design by
Engineering Bulletin Board System (EBBS)
POBox 75537, Los Angeles, Calif. 90075
Does anyone know where i can get a good copy of this program/file?
 I currently use either Excel or preferabley Qpro 8
 As a side remark i tried Qpro10 and it continues to crash.
I went back to Qpro8 after not being able to get any support from Corel.
RE: concrete design spread sheet
Are you sure the file is corrupt and Qpro is just not having problems importing it for some reason?  Do you know anyone with a copy of Lotus that you could try importing it into to?  Have you tried Excel, perhaps it could handle the import?
Those are long shots but I'd try them if it was a spreadsheet I wanted.  Unfortunately, I can't help you in getting another copy.
Bylar,
I cant help you with your file corruption problem but here is a link to free spreadsheet files for concrete (and other) design. It is a UK site but you may be able to adapt the workbooks to US codes. I have tried most of the files with QPro10 and havent had any problems. Dodgy music!
http://www.structural-engineering.fsnet.co.uk/
AJUK
