Submitted and then frozen Job (runing)
The job is sumbmitted
Under the job (Submitted)
and
The job input file "Dam1" has been submitted for analysis.
After that the Proccessing is frozen
The Dam1(runing) doesnot appear
Any body can tell why the JOB in not runing
There is no mistake in the modeling itself because yesterday the same job was completed
RE: Submitted and then frozen Job (runing)
After submitting the job, (in the "pre-" phase) ABAQUS analyzes the model data for potential weird stuff (i.e. prone to error) one might have put in the model, before the .inp file is generated and the solver is launched.
In some cases this period can take a significant amount of time.
Dear xerf
The same job used to start Runing quickly (5-10 Seconds) , why now it takes at least 10-15 minutes.
Is something wrong with my ABAQUS as far as my PC is concerned
Maybe some of the licensing processes for the solver (either client or server side).......???
Xerf
I could not understand what you meant, but now the Job is completely frozen at (Submitted). I have been waiting for three hours but it is still frozen
I have this problem once. What I did I turned off the machine and log in again. then, it solved.
I was saying regarding to what may be wrong that:
....maybe some of the licensing processes for the solver (either client or server side) stopped working properly.
ABAQUS checks the license validity from times to times. If the license verification (which is ensured by separate processes) fails (e.g. solver license), it might be possible to get in such a situation...I think. For the beginning, you should try to restart your machine....as azidah said.
i did turn it on and off but i still have the same issue. For 2 days now i couldnot do any work
Abaqus help desk ?
hi hpp,
did u try to delete the job and create a new job and submit it again?
I deleted the job and log off and shut down the laptop for couple hours.
We had some problems with this from our firewall software (Symantec).  Before submitting the job, we had to disable the firewall, else information wouldn't be sent correctly.  The job generally *would* run, it just wouldn't show progress or that it was completed (have you tried just hitting Results, to see if anything has happened?).
I don't think it is the firwall or licensing process problem if you can play around in the CAE mode.
