Copying Sheets
Copying Sheets
Copying Sheets
Does anybody know of a method to copy and paste a sheet within a drawing file?
RE: Copying Sheets
Do you mean the format? Are you trying to make muli shts in one dwg file?
Chris
SolidWorks 07 2.2/PDMWorks 07
AutoCAD 06
ctopher's home (updated 02-10-07)
RE: Copying Sheets
Not the format, that's just choosing the add a sheet option. I want to create a dwg, dimension it and all that good stuff, then, within the same file, create an exact duplicate of the sheet i just finished without having to go through the entire process again.
RE: Copying Sheets
Create the second sheet then copy and paste all the views to the new sheet.
cheers
RE: Copying Sheets
That's Cheating! I like it.
