Snap to point?
Snap to point?
If I drop a point or points in sketcher and I create a circle for example. I cant get the line of the circle to snap to the point i dropped. Any ideas?
RE: Snap to point?
If points are in another sketch, you need to project them in your working sketch.
Then smartpick should find points and allow you to have coincidence.
RE: Snap to point?
RE: Snap to point?
delete CATSettings files but do not change Folder name.
Points and circle in same sketch ?
RE: Snap to point?
any file give the same result ?
RE: Snap to point?
Usually I just rename the catsettings so if the new catsettings folder doesnt fix the issue i can rename the old folder back to catsettings and delete the new one.
RE: Snap to point?
i am new to r16 debugging.
