PTC thermistors
PTC thermistors
PTC thermistors
Does anyone have a source for surface mount PTC thermistors? Specifically, I am looking for a thermistor that would have a room temperature value in the 10k to 30k range and a 0.4%/*C or higher slope.
The only supplier I found that had PTCs with that high of a resistance was a place called Quality Thermistor (thermistor.com). The prices they quoted were unbelieveable - not only were they not in the ballpark, they weren't in the same state.
thanks in advance.
RE: PTC thermistors
besides thermistor you can use special temp.sensor IC
or even transistor or diode as sensor.
What is your application? How many/year? What kind of accuracy do you need?
Please read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
RE: PTC thermistors
Quality Thermister is frankly... an embarrasment. Their prices are so far beyond usable I too shake my head.
Have you done a Digikey or Mouser search?  Digikey shows 12 pages of PTCs in its search engine(perhaps they're all fuses though).
Keith Cress
RE: PTC thermistors
yes, I've searched through those sources. I'm thinking I will have to find some other route. The problem is it has to be as cheap as possible - customers won't want to implement this if it is too expensive.
The PTC would be used as a direct replacement for a resistor in the analog system loop.
