Can "*Debond" do the 3D crack propagation ?
I used "*Debond" and "*Fracture criterion" for studing the crack propagation.
the 2D model has well passed. but not for 3D model. Abaqus indicate theses two errors :
*surface behavior,augmented lagrange keyword cannot be used if *initial condition,type=contact is specified
The *debond keyword is only valid for planar or axisymmetric contact surfaces. Slave surface assembly_surf_slave is not of this type
can't *Debond really treat 3D crack propagation ?
I have ever seen some examples of 3D crack propagation in Abaqus, How can they do it ?
RE: Can "*Debond" do the 3D crack propagation ?
"Crack propagation analysis:
-models quasi-static crack growth in two dimensions (planar and axisymmetric);"
I think you can model crack propagation in 3D using cohesive elements instead of debonding.
Also, you might be interested in Zencrack:
http://www.zentech.co.uk/zencrack.htm
I would like to simulate a crack growth. Is it possible to make an analysis where the load applied and the crack (as nodes release) are in function of time?
Thanks in advance,
Albert
by the way,
In the keywords of "*fracture criterion", there are these phrases :
Data lines to define the critical stress criterion (TYPE=CRITICAL STRESS):
First line:
1. Normal failure stress, x1.
2. Shear failure stress, y1.
3. Shear failure stress, y2. (Not applicable in two dimensions.)
if *Debond can't do 3D, in "*fracture criterion", why there are still a "y2" which seems to be applied for 3D ?
I have not tried it, but I think the procedure might work if the surfaces to be debonded are planar (in 3D). Then, the documentation and the error message you got would make more sense.
