Liquid level (HLL & LLL) calculation of tank?
Hello All,
I'm trying to claculate liquid level (HLL & LLL) in tank?
Could anybody explain how to calculate it .... and also How to calculate the overflow line of the tank ... espcially for chemical tanks
RE: Liquid level (HLL & LLL) calculation of tank?
The High liquid level and Low liquid level will depend grately on your application and your needs, the residence time you want for you tank, the hydrostatic pressure you need to have, this is a very general question, if you could describe your process a little bit more it would help
The HLL is typically chosen as 90% full. Tanks are not usually operated to reach 100% full during normal operations. The LLL is typically the minimum level required for pump operation. If you run below that, you are probably going to damage the pump.
These are general guidelines.
The levels would differ for horizontal and vertical tanks; as well as normally empty vessels like a suction scrubber from an amine contactor.
Look at API RP-14C.
HL and HHL are set in the field by operations.  We (us'n engineers) set design factors for residence time needed, and generally assume practices for operating vessels.  Once the separator is in operation, the levl tgransmitter is off, the desity of the phases are slightly different, flowrates are swinging, on and on.  The HL and LL are set initially by the engineers, but operations should adjust to meet the actual conditions.  I normally specify LL at 1/2 the normal and HL at 1/2 the amount between normal and 90%, knowing full well operations will change.  Saying that, if a volume of liquid exceeds a regulatory limit or relief valve sizing for a fire case, THEN make the HL a madated level that cannot change in your documentation.
More details on the liquid are necessary.
High vapor pressure?  Flammable?
Variations in temperature.
Storage or process tank...
Some additions to above.
Do you mean Alarm settings or trip settings - I Presume alarm only (right?) and i know Normally LSHH = trip and LSH=alarm but it depends on where you are and your company codes/location which each one means. I have seen HLL = Trip settings.
