really small failsafe (spring applied or permanent magnet) brake?
Does anyone out there know of any "subminiature" spring-applied or permanent-magnet failsafe brakes?
I'm looking for something to hold only about 0.04Nm (about 5.7 in-oz), and under 20-25mm diameter.
Thoughts? Leads?
Bruce
RE: really small failsafe (spring applied or permanent magnet) brake?
Not so clear what you are after. Can you give more info about the application?
How many do you need?
Mike Halloran
Pembroke Pines, FL, USA
israelk: thanks for the reply. Permanent magnet or spring-applied failsafe brakes are pretty standard things. Very common on robot arms that have maintain their position even if the power fails - think "parking brake".
There are many manufacturers of larger sizes, but I'm on the hunt for a small one, which are much less common. Examples can be found in an old Puma-260, but there are no vendor markings. The only source I have found is the old Vernitron line now being built by Island Components.
MikeHalloran: I'm looking for a handful of prototypes right now, but am ultimately looking for a ISO supplier for volume production of 1000's of units for a surgical robot. Do you have any leads?
Alternatively, I'm considering designing the unit myself if I have to, in order to get the size I require.
Thanks!
-Bruce
The smallest I see from Ogura seems to be 40 mm but they may have smaller special units.
http://www.ogura-clutch.com/#
