try to buy a shaping machine
We search a shaping machine for small module gears cutting (from EU, second hand). On all sites, i find only big machines. I need a "TIP".
RE: try to buy a shaping machine
rather than hobbed or shaped?
What kind of accuracies do you need.
Small is relative. You might want to check out
spline machine tooling.
The part is a group of gears, one can be hobbed but one can not, or a pinion that can not be hobbed. Also we speak about gears under "module 1", and precisions 6, 7, 8 DIN (11, 10, 9 AGMA). I believe EDM is not a solution.
Small machines cannot make big parts.
Big machines in decent shape can make small parts.
Mike Halloran
Pembroke Pines, FL, USA
Like Mike says, why can't a large
machine hob your small pinion?
There are plenty of small Fellows High Speed No 7s on the US ebay site at the moment. Just go to www.ebay.com and do a search in Business & Industrial.
Thank's
