bond eurathene foam with rubber
I have one of the application to bond eurathene foam with NBR-PVR rubbber? Does anyone have suggestion how to joint two components?
RE: bond eurathene foam with rubber
You might want to give these people a call. There several possibilities like a contact cement or adhesive latex to name two, that could work depending to the environment they the bond will see.
http://www.masterbond.com/
